I got a WDS link setup between two hAP lite.
The problem is, that the link is only “stable” for a view hours, then starts to drop out and finally refuses to connect (permanently tries to but immediately disconnects again).
When i reboot the WDS master, the link is up again stable and fine until after a while the same scenario starts again.
The WDS link is set up as virtual interface on both sides.
It seems a bit to me as if there was a problem with memory leak or buffer that run full?
Anybody got an idea how i could further track down the problem?
thanks
