Hello Friends,
Please what happens when WDS is enabled on a wifi enabled RB? see pics attached
The best way to describe a WDS link is something like this:
A WDS link will pass all the MAC address between the remote network and the local network. The ARP table shows all MAC address on both sides of a WDS link.
A typical non-WDS link normally passes only a single MAC address (I stated normally one MAC address).
So, if you have two networks which both need to shave the same IP network with multiple devices on both sides of the network, then you would want to use WDS.
North Idaho Tom Jones
