Does anyone know how many AP’s running WDS you can have connected to one RB532 With Router OS with one radio card ?
The links are all AP’s running WDS to the main AP only and no WDS between AP’s
Cheers
Piri
Cheers
Piri
WDS creates latency, i suggest not to connect more than 8 WDS clients.
Best regards
Only difference between WDS and not WDS is a 6 byte overhead… There should be no real difference in performance..
/Henrik
