WDS - LINK "disconnected, received deauth: reserved (0) "
i have a problem with my PtP and I want to be sure my wifi card is broken.
This is my configuration:
SITE A
wlan1
Wireless (Atheros AR5413) AR5006X 802.11abg NIC (rev: 1)
I then created four wds and for each a static mesh.
All this works fine but sometimes the wds are disconnected.
I checked the page mentioned in the forum: http://wiki.mikrotik.com/wiki/Wireless_Debug_Logs
Attach file diskwifi.site.a.txt, these are the errors from the site a.
diskwifi.site.a.txt (11.4 KB)
SITE B
wlan1
Wireless (Atheros AR5413) AR5212 802.11abg NIC (rev: 1)
Same configuration.
I used this guide http://wiki.mikrotik.com/wiki/802.1q_Trunk_extension_over_Wireless_P2P_Link
I used as WPA PSK with AES com
Attach file diskwifi.site.b.txt, these are the errors from the site b.
diskwifi.site.b.txt (8.13 KB)
Unfortunately I don’t found all the answers and I can’t decide if the problem is the card broken of the site a or b, likely weak signal, strong interference.
I have seen work well with Signal Strength -91.
Thank You
