WDS Link Down
Hi all,
I have an Rb433 with 3 R52 cards in. The unit has been working fine for ages, i have noticed today that one link is down. on further inspection the MAC address of this card appears to be 00:00:00:00:00:00.
Is the a faulty card or can i rectify this remotley?
Thanks in advance
See screen dump below:
[admin@MikroTik] /interface wireless info> print
0 interface-type=Atheros AR5413 chip-info=“mac:0xa/0x5, phy:0x61, a5:0x63, a2:0x0, eeprom:0x5002” pci-info=“00:12.0”
capabilities=tx-power-control,ack-timeout-control,virtual-ap,alignment-mode,noise-floor-control,scanning,burst-
support,nstreme,sniffing,power-channel,wmm
default-periodic-calibration=enabled
supported-bands=2ghz-b,5ghz,5ghz-turbo,2ghz-g,2ghz-g-turbo,5ghz-10mhz,5ghz-5mhz,2ghz-10mhz,2ghz-5mhz
2ghz-b-channels=2412:0,2417:0,2422:0,2427:0,2432:0,2437:0,2442:0,2447:0,2452:0,2457:0,2462:0
5ghz-channels=5180:0,5200:0,5220:0,5240:0,5260:0,5280:0,5300:0,5320:0,5745:0,5765:0,5785:0,5805:0,5825:0
5ghz-turbo-channels=5210:0,5250:0,5290:0,5760:0,5800:0
2ghz-g-channels=2412:0,2417:0,2422:0,2427:0,2432:0,2437:0,2442:0,2447:0,2452:0,2457:0,2462:0
2ghz-g-turbo-channels=2437:0 5ghz-10mhz-power-channels=5175:0,5180:0,5185:0,5190:0,5195:0,5200:0,5205:0,5210:0,
5215:0,5220:0,5225:0,5230:0,5235:0,5240:0,5245:0,5255:0,
5260:0,5265:0,5270:0,5275:0,5280:0,5285:0,5290:0,5295:0,
5300:0,5305:0,5310:0,5315:0,5320:0,5325:0,5740:0,5745:0,
5750:0,5755:0,5760:0,5765:0,5770:0,5775:0,5780:0,5785:0,
5790:0,5795:0,5800:0,5805:0,5810:0,5815:0,5820:0,5825:0,
5830:0
5ghz-5mhz-power-channels=5175:0,5180:0,5185:0,5190:0,5195:0,5200:0,5205:0,5210:0,5215:0,5220:0,5225:0,5230:0,
5235:0,5240:0,5245:0,5255:0,5260:0,5265:0,5270:0,5275:0,5280:0,5285:0,5290:0,5295:0,
5300:0,5305:0,5310:0,5315:0,5320:0,5325:0,5740:0,5745:0,5750:0,5755:0,5760:0,5765:0,
5770:0,5775:0,5780:0,5785:0,5790:0,5795:0,5800:0,5805:0,5810:0,5815:0,5820:0,5825:0,
5830:0
2ghz-10mhz-power-channels=2412:0,2417:0,2422:0,2427:0,2432:0,2437:0,2442:0,2447:0,2452:0,2457:0,2462:0
2ghz-5mhz-power-channels=2412:0,2417:0,2422:0,2427:0,2432:0,2437:0,2442:0,2447:0,2452:0,2457:0,2462:0
1 interface-type=Atheros AR5413 chip-info=“mac:0xa/0x5, phy:0x61, a5:0x63, a2:0x0, eeprom:0x5002” pci-info=“00:13.0”
[admin@MikroTik] /interface wireless registration-table> print
INTERFACE RADIO-NAME MAC-ADDRESS AP SIGNAL-STRENGTH TX-RATE UPTIME
0 To_Hookup 000C422C4740 00:0C:42:2C:47:40 yes -27dBm@6Mbps 54Mb… 3m59s
[admin@MikroTik] /interface wireless wds> print
Flags: X - disabled, R - running, D - dynamic
0 R name=“wds1” mtu=1500 mac-address=00:0C:42:2C:47:41 arp=enabled master-interface=To_Hookup
wds-address=00:0C:42:2C:47:40
1 name=“wds2” mtu=1500 mac-address=00:00:00:00:00:00 arp=enabled master-interface=To_Orchard
wds-address=00:0C:42:2C:47:43
