I have about 6 D-Link APs in wds mode with my Mikrotik and the link goes off more then often. Actually it goes off every 5mins or less. Does anyone have an idea.
Also i was trying to create a WDS link between Mikrotik and another radio. I got a connection but there was no data transfer. When i checked the status of both radios i foudn out that the other radio was sending and recieving packets on the wireless interface and it was connected but the Mikrotik was only sending but not recieving . I am using wep as security and the signal strength on scan seems far enought about 48%
Does anyone know the cause and most importantly the solution of any of this problems any contribution would be greatlly appreiciated.
