wds, mesh and 11n
For hwmp+ all routers should work in the mode of ap-bridge + wds dynamic (or static) mesh. In this mode, the TX/PX rate does not exceed 54Mbps. Bandwidth does not show more than 23 Mbit/s. When you switch to one of the points in the treatment station or station wds these problems are solved (the point immediately turn into the 130Mbps-HT), but, of course, stops working mesh, since the point in the mode of station and station-wds no longer accepts connections from the neighboring nodes . How to solve the problem?
I’ve got the same issue. And the same again if I want to use nstream or nv2…
Why? There some incompatibility between wireless protocol and hwmp+? (i try 4.16, 5rc5 and 5rc6 with lastest firmware)
Good luck with that, that’s my question as well. Station-WDS and Mesh.
As I understand it, “station-WDS” mode supposedly solves the problem, being able to carry 4 MAC addresses instead of 3 in “station” mode, but in practice, I’ve had no success.
Any advice?
