KimC
August 14, 2006, 5:33pm
1
Hello !
Please consider the following setup (classic repeater):
Router 1:
wlan1: client, 5.x Ghz Uplink - subnet A
wlan2: ap-bridge, 2.4 Ghz, wds, rstp, bridge wlan2 - subnet B
Router 2:
wlan1: ap-bridge, 2.4 Ghz, wds, rstp, bridge wlan1 - subnet B
I would like all 2.4 GHz clients on both routers to use same subnet. Please tell me what to do - my hair is getting grey :-o
Regards
KimC
GWISA
August 15, 2006, 3:38pm
2
Where exactly are you having a problem? Routing from A to B?
KimC
August 15, 2006, 9:22pm
3
The routing should be simple as I see it. However:
Router 1:
wlan1, 5 GHz client, 10.1.1.10/24 on wlan1
wlan2, 2.4 GHz ch6, ap-bridge, wds, rstp, bridge wlan2, 10.10.10.1/24 on bridge1
Router 2:
wlan1, 2.4 GHz ch6, ap-bridge, wds, rstp, bridge wlan1, 10.10.10.2/24 on bridge1
A laptop with 10.10.10.200/24 connects, neighborviewer discovers both routers, but ip-traffic does not work.
I have made lots of MT stuff before, but I haven’t tried this setup before. It might just be a simple error, but no luck so far. I guess, that it has something to do with the bridging,but I’m not sure…
GWISA
August 16, 2006, 6:33am
4
You may need proxy-arp on thr bridge?
KimC
August 17, 2006, 4:43pm
5
It seems, that I got it solved. The trick was to add BOTH wds and wireless to the bridge.
Uldis paper on meshing didn’t mention this - and really, the docs are almost invisible in this area.
Now I have to test the solution a little, before moving to the production environment.
Thank you anyway, GWISA
GWISA
August 17, 2006, 9:11pm
6
Aaah yes - i assumed you’d set the default bridge on WDS…
That’s definitely the answer
KimC:
Don´t was documented because they are using WDS in the backbone dedicated links in 5Ghz, not in the same 2.4Ghz used to distribution…
Regards!
Alessio
