Wds network
Please look at the following picture and tell me whether or not it is possible to implement this network topology.
please bear in mind that each mast has a switch and provide two vlans one for dynadish wds network and other for metal.
i want to create wds backhaul network on 5 Ghz on DynaDiah and 2.4G on metal
Thanks in advance
Sent from my SM-N910C using Tapatalk
It is possible, however I wouldn’t use a switch but a router (like the soon to be released Hex Poe for example) at the towers.
You’ll still be able to power the antennas, and additionaly you can segment the hops and deploy OSPF (cutting L2) on the routers to implement a dynamic, automatic solution; you will also be able deploy MPLS, TE, etc
Cannot see where would you be deploying WDS; it is not needed anyway.
there is mobile vehicle which move in that soecific teritory. so he is connected through metal with omni directional anntena. that is why i need wds because i dont want the lind drop
You plan to build 3km PTPs between the Metals with an omni antenna? that’s a no-no, and even if it worked (highly doubt that) adding WDS on top would be the last “icing” of the nightmare, as you’ll be forced to use regular 802.1 for that instead of a TDMA protocol (nstreme, Nv2) for the PTP.
Use the most directional and shielded antennas to build the 2.4GHz PTPs, and add grooves + omni in the rare event the 2.4GHz spectrum being clear, or SXT2 as sectors or to provide connectivity for roaming agent.
absolutely not correct. let me tell you exactly whats the plan.
we have 4 towers which each contain 2 Dyna dish which is connected in 5Ghz band and we have again 4 RBMETAL with omni directional anntena which is again using the Dynadish to transfer the data to main building. there is a car with RBMETAL which is directly connected to other RBMETAL IN 2.4GHz and can transfer the data through the area and has the roaming capability. i will mention again that RBMETALS are all having omni directional antenna as using other other anyenna for 2.4 is not viable for us an antennae are all 6db
i just want to know is it possible or not? if not what other options do i have? there is no onterference in the area. we need the car to be able to connect through its omni dorectional anntena to other RBMETAL with omni anntena with in 2km distance
any more suggestio?
i just want to make sure is it possible or not?
i am.still looking for an proper solution so please i will be greatful if anyone can help.
thanks
This is correct network topology, your design should work fine.
Your terminology is incorrect! This is not WDS or Mesh… In WDS/Mesh you would remove the PtP links and the NetMetals would communicate directly to one another as well as the clients. Or remove the NetMetals and have the DynaDishes communicate directly to each other as well as clients. This is what caused the earlier confusion.
the problem is i want to send data from car to RBMETAL through 2.4 GHz and send the same data through DYNADISH to main building
can i use the same network topology and implement mesh network with roaming capabilities?
