hallo,
i try to make a network composed from the following:
1 IP camera (192.168.0.219) connected to a RB112 (with R52) at Lan port.
1 Router Board RB112, connected to the above mentionned camera, running in AP Bridge mode, wds enabled, the router board has the following configuration:
interface:
0 R ether1 ether 0 0 1500
1 R wlan1 wlan 0 0 1500
2 wds1 wds 0 0 1500
wireless:
0 R name=“wlan1” mtu=1500 mac-address=00:0C:42:0C:01:37 arp=enabled
disable-running-check=no interface-type=Atheros AR5413
radio-name=“000C420C0137” mode=ap-bridge ssid=“Trixbox” area=“”
frequency-mode=manual-txpower country=united states antenna-gain=0
frequency=2417 band=2.4ghz-onlyg scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=“” basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=yes update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=short compression=no
allow-sharedkey=no
WDS:
0 name=“wds1” mtu=1500 mac-address=00:0C:42:0C:01:37 arp=enabled
disable-running-check=yes master-interface=wlan1
wds-address=00:C0:02:C2:EE:6A
IP Addresses:
0 192.168.0.220/16 192.168.0.0 192.168.0.255 ether1
1 192.168.0.8/24 192.168.0.0 192.168.0.255 wlan1
IP route:
0 ADC 192.168.0.0/24 192.168.0.8 wlan1
1 ADC 192.168.0.0/16 192.168.0.220 ether1
2 A S 0.0.0.0/0 r 192.168.0.8 wlan1
the third party is an Alfa router: configured with WDS, with the MAC adress of the RB112.
i don’t know, but i think i done all things like described, but still not running (the alfa router is also running WDS with another peer, and working well).
has the country selection to do with this (in the alfa router no possibility to select country), i tried both static and dynamic WDS. i’m using channel 2 in all devices and the same SSID
can you please help me
thank you
