I set up WDS on three 532’s that I just got. Level 4 license running .31 firmware. When I have two AP’s with one as a hotspot and both in WDS it works great to the Internet with perfect ping times routed between on /24 network on WLAN with the hotspot assigning the DHCP. I can connect to either AP and it goes to the hotspot on AP1 and connects and goes out on the internet with a public IP assigned to the Ether1 connection. The problem is when I add the third AP all the ping times go bad and the WLAN Interface and Bridge Interface goes to 500 to 1000 kbps and everything slows down. I do a sniffer on the packets and it says they are talking port 17 UDP almost 1000 per second. I have looked through all the help pages and can’t seem to find an answer. I have set it up according to help pages and it does not seem to matter if it is dynamic or if I click and make the WDS static. Anyone know the answer or what I may be doing wrong?
Thanks-
