I’m following how-to “Transparent Bridge, using WDS”. I have few questions. First how to understand what is the current “ccq” and connection between 2 WDS mikrotiks (2.9.x).
Second is there a problem bridge-ing wds-wirelesses with VLANs not with NICs ? I’ve try to run it, but i’ve got only ping and trace, when I try to open a page, my browser start to download the page and pings time out. When I try to log on IRC I’ve got the same issue, irc client start to recive data and just freezes.
edit:
I just saw this link.
http://www.mikrotik.com/docs/ros/2.9/interface/wireless.content#4.13.21.2
The difference between this and “the old” how-to is that station should use mode=station-wds. Will that resolve my questions?
I’ll try it today …
Edit2:
Problem solved, but I’ve got another interesting issue. I set ip address to wlan1 (on MT1) to 10.44.123.1/30 and ip addreess 10.44.123.2/30 on wlan1 (on MT2). Wirelesses are configured like the example from the url above. And I can’t ping 10.44.123.2 from 10.44.123.1 and reverse …
P.S. The problem was from NIC that doesn’t support VLANs good (I’ll detached it after half an hour and paste here the chipset …)
