My friends i will try to bandwidth management from the station-wds for the pc the schema is like that
internet → AP ---------Station-WDS —> PC
190.
but only queue traffic for download not upload what can i do??? my configuration is next i try to queue interface and i dont have a solution for this trouble.
Note i try to mark the connection and only mrk packets to src-address no dst-address if any can help me .. Thanks a lot
/ interface vlan
add name=“vlan1” mtu=1500 arp=enabled vlan-id=1 interface=bridge1 comment=“”
disabled=no
add name=“vlan40” mtu=1500 arp=enabled vlan-id=40 interface=ether1 comment=“”
disabled=no
/ interface ethernet
set ether1 name=“ether1” mtu=1500 mac-address=00:0C:42:15:8B:41 arp=enabled
disable-running-check=yes auto-negotiation=yes full-duplex=yes
cable-settings=default speed=100Mbps comment=“” disabled=no
/ interface wireless
set wlan1 name=“wlan1” mtu=1500 mac-address=00:0B:6B:0B:50:CD arp=enabled
disable-running-check=no radio-name=“Remoto1” mode=station-wds
ssid=“TestCuosa” area=“” frequency-mode=manual-txpower
country=no_country_set antenna-gain=0 frequency=5180 band=5ghz
scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic
wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=yes update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=both compression=no allow-sharedkey=no comment=“”
disabled=no
/ interface wireless nstreme
set wlan1 enable-nstreme=no enable-polling=yes framer-policy=best-fit
framer-limit=2400
/ interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
/ interface wireless security-profiles
set default name=“default” mode=none authentication-types=“”
unicast-ciphers=“” group-ciphers=“” wpa-pre-shared-key=“”
wpa2-pre-shared-key=“” eap-methods=passthrough tls-mode=no-certificates
tls-certificate=none static-algo-0=none static-key-0=“” static-algo-1=none
static-key-1=“” static-algo-2=none static-key-2=“” static-algo-3=none
static-key-3=“” static-transmit-key=key-0 static-sta-private-algo=none
static-sta-private-key=“” radius-mac-authentication=no group-key-update=5m
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no
audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no
frames-per-second=25 audio-min=-100 audio-max=-20
/ interface wireless access-list
add mac-address=00:15:6D:53:D8:71 interface=wlan1 authentication=yes
forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none
private-key=“” comment=“Base test " disabled=no
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no
memory-limit=10 file-name=”" file-limit=10 streaming-enabled=no
streaming-server=0.0.0.0 streaming-max-rate=0
/ interface bridge
add name=“bridge1” mtu=1500 arp=enabled stp=no priority=32768 ageing-time=5m
forward-delay=15s garbage-collection-interval=5s hello-time=2s
max-message-age=20s comment=“” disabled=no
/ interface bridge port
add interface=ether1 bridge=bridge1 priority=128 path-cost=10 comment=“”
disabled=no
add interface=wlan1 bridge=bridge1 priority=128 path-cost=10 comment=“”
disabled=no
/ ip ipsec proposal
add name=“default” auth-algorithms=sha1 enc-algorithms=3des lifetime=30m
lifebytes=0 pfs-group=modp1024 disabled=no
/ ip accounting
set enabled=no account-local-traffic=no threshold=256
/ ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
/ ip service
set telnet port=23 address=0.0.0.0/0 disabled=no
set ftp port=21 address=0.0.0.0/0 disabled=no
set www port=80 address=0.0.0.0/0 disabled=no
set ssh port=22 address=0.0.0.0/0 disabled=no
set www-ssl port=443 address=0.0.0.0/0 certificate=none disabled=yes
/ ip upnp
set enabled=no allow-disable-external-interface=yes show-dummy-rule=yes
/ ip arp
/ ip socks
set enabled=no port=1080 connection-idle-timeout=2m max-connections=200
/ ip dns
set primary-dns=0.0.0.0 secondary-dns=0.0.0.0 allow-remote-requests=no
cache-size=2048KiB cache-max-ttl=1w
/ ip traffic-flow
set enabled=no interfaces=all cache-entries=4k active-flow-timeout=30m
inactive-flow-timeout=15s
/ ip address
add address=172.20.9.16/21 network=172.20.8.0 broadcast=172.20.15.255
interface=vlan1 comment=“” disabled=no
add address=190.70.102.122/24 network=190.70.102.0 broadcast=190.70.102.255
interface=ether1 comment=“” disabled=no
/ ip proxy
set enabled=no port=8080 parent-proxy=0.0.0.0:0 maximal-client-connecions=1000
maximal-server-connectons=1000
/ ip proxy access
add dst-port=23-25 action=deny comment=“block telnet & spam e-mail relaying”
disabled=no
/ ip neighbor discovery
set ether1 discover=yes
set wlan1 discover=yes
set bridge1 discover=yes
set vlan1 discover=yes
set vlan40 discover=yes
/ ip route
/ ip firewall connection tracking
set enabled=yes tcp-syn-sent-timeout=5s tcp-syn-received-timeout=5s
tcp-established-timeout=1d tcp-fin-wait-timeout=10s
tcp-close-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-time-wait-timeout=10s tcp-close-timeout=10s udp-timeout=10s
udp-stream-timeout=3m icmp-timeout=10s generic-timeout=10m
tcp-syncookie=no
/ ip firewall service-port
set ftp ports=21 disabled=no
set tftp ports=69 disabled=no
set irc ports=6667 disabled=no
set h323 disabled=yes
set quake3 disabled=no
set gre disabled=yes
set pptp disabled=yes
/ system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet
enter-setup-on=any-key cpu-mode=power-save memory-test=no
cpu-frequency=175MHz boot-protocol=bootp enable-jumper-reset=yes
/ system logging
add topics=info prefix=“” action=memory disabled=no
add topics=error prefix=“” action=memory disabled=no
add topics=warning prefix=“” action=memory disabled=no
add topics=critical prefix=“” action=echo disabled=no
/ system logging action
set memory name=“memory” target=memory memory-lines=100 memory-stop-on-full=no
set disk name=“disk” target=disk disk-lines=100 disk-stop-on-full=no
set echo name=“echo” target=echo remember=yes
set remote name=“remote” target=remote remote=0.0.0.0:514
/ system upgrade mirror
set enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0
check-interval=1d user=“”
/ system clock manual
set time-zone=+00:00 dst-delta=+00:00 dst-start=“jan/01/1970 00:00:00”
dst-end=“jan/01/1970 00:00:00”
/ system watchdog
set reboot-on-failure=yes watch-address=none watchdog-timer=yes
no-ping-delay=5m automatic-supout=yes auto-send-supout=no
/ system console
add port=serial0 term=“” disabled=no
/ system identity
set name=“testclient”
/ system note
set show-at-login=yes note=“”
/ port
set serial0 name=“serial0” baud-rate=auto data-bits=8 parity=none stop-bits=1
flow-control=hardware
/ queue type
set default name=“default” kind=sfq sfq-perturb=5 sfq-allot=1514
set ethernet-default name=“ethernet-default” kind=pfifo pfifo-limit=50
set wireless-default name=“wireless-default” kind=sfq sfq-perturb=5
sfq-allot=1514
set synchronous-default name=“synchronous-default” kind=red red-limit=60
red-min-threshold=10 red-max-threshold=50 red-burst=20 red-avg-packet=1000
set hotspot-default name=“hotspot-default” kind=sfq sfq-perturb=5
sfq-allot=1514
add name=“PCQ_download” kind=pcq pcq-rate=64000 pcq-limit=50
pcq-classifier=dst-address pcq-total-limit=2000
add name=“PCQ_upload” kind=pcq pcq-rate=64000 pcq-limit=50
pcq-classifier=src-address pcq-total-limit=2000
add name=“default-small” kind=pfifo pfifo-limit=10
/ queue simple
add name=“coladescraga” target-addresses=190.70.102.121/32
dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8
queue=default/default limit-at=64000/64000 max-limit=64000/64000
burst-limit=64000/64000 burst-threshold=32000/32000 burst-time=1s/1s
total-queue=default time=0s-1d,sun,mon,tue,wed,thu,fri,sat disabled=no
/ user
add name=“admin” group=full address=0.0.0.0/0 comment=“system default user”
disabled=no
/ user group
add name=“read” policy=local,telnet,ssh,reboot,read,test,winbox,password,web,!f
tp,!write,!policy
add name=“write” policy=local,telnet,ssh,reboot,read,write,test,winbox,password
,web,!ftp,!policy
add name=“full” policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbo
x,password,web
/ user aaa
set use-radius=no accounting=yes interim-update=0s default-group=read
/ tool bandwidth-server
set enabled=yes authenticate=yes allocate-udp-ports-from=2000 max-sessions=10
/ tool mac-server ping
set enabled=yes
/ tool e-mail
set server=0.0.0.0 from=“<>”
/ tool sniffer
set interface=all only-headers=no memory-limit=10 file-name=“” file-limit=10
streaming-enabled=no streaming-server=0.0.0.0 filter-stream=yes
filter-protocol=ip-only filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535
/ tool graphing
set store-every=5min
/ radius incoming
set accept=no port=1700
/ snmp
set enabled=no contact=“” location=“”
/ snmp community
set public name=“public” address=0.0.0.0/0 read-access=yes
