WDS random Disconnect / Reconnect - some times reboot- ??
Two 532s one with 2 radio’s one with one as wds.
Problem: the wds slave unit will disconnect (shows “no beacons” or “sent deauth” in log on master) then reconnect like 20-50seconds later. it sometimes will keep doing this for while.
Both show -67 to -70 signal, both are 8602 radios
here are the ints;
0  R name="wlan1" mtu=1500 mac-address=00:02:6F:3E:1F:1C arp=enabled disable-running-check=no interface-type=Atheros AR5413
      radio-name="00026F3E1F1C" mode=ap-bridge ssid="bc_3c2R"
      area="" frequency-mode=manual-txpower country=no_country_set
      antenna-gain=0 frequency=2437 band=2.4ghz-b scan-list=default
      rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
    54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
      ack-timeout=indoors tx-power=30 tx-power-mode=all-rates-fixed
      noise-floor-threshold=default periodic-calibration=default
      periodic-calibration-interval=60 burst-time=disabled dfs-mode=none
      antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=bridge1
      wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
      update-stats-interval=disabled default-authentication=yes
      default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
      hide-ssid=no security-profile=default disconnect-timeout=3s
      on-fail-retry-time=100ms preamble-mode=both compression=no
      allow-sharedkey=no
And on the recieving end wds:
0  R name="wlan2" mtu=1500 mac-address=00:02:6F:3D:90:74 arp=enabled
      radio-name="00026F3D9074" mode=ap-bridge ssid="bc_3c2R"
                          54Mbps
      ack-timeout=dynamic tx-power=30 tx-power-mode=all-rates-fixed
      hide-ssid=no security-profile=default disconnect-timeout=10s
      allow-sharedkey=no
any ideas?
thanks
What power source do ya use ?
What radio do have that can make 1W (30dBm) of power – tx-power is set to 30dBm? As I know, there no such radio. You are overdriving the radio and therefore the problem.
DONT CHANGE THINGS THAT YOU DONT UNDERSTAND
I suggest the you reset the entire config back to default “/system reset” – and be sure that you have a serial cabled connected when you do that.
John
hmm..ok i knew that 30dbm was ~ 1 Watt and i knew the 8602 could not push that but here is the reason i switched it from 26dbm:
On serveral of my Ap’s i will see someone connect at a low RSSI, with alot of packetloss as identfied by pining them. i noticed that by switching the default TX power from 26 to 30 it would ALWAYS help.
I know im potentially blasting at the small laptop wifi radio pretty hard, which should make it harder for me to hear it back, but i’ve seen to work WAY to many times to say it hocus pocus.
now the WDS slave is reassosicating every hour, some times twice an hour. A while back when i was having this issue i remeber setting the wds slave to Station instade of APB and that helped it maintain connectivity, but was not what i needeed as i need the WDS slave to accept clients.
i’m going to try lowering both slave and master to 26dbi. and will report back.
thanks for the quick responses!!
joe
EDIT: setting the slave at 26 and the master at 26 has caused the RSSI to drop 5 db..what ever its worth…not a prob since im at -72
EDIT2: Still getting disconnects every 4 hours or so, but they are not long enough to cause a reboot like before.
anyone??
periodic calibration under wireless advanced settings set to “enable”?
that seems to make a difference for us sometimes…
SMA
thanks for the response, but i enabled that about 3 hours ago and it just did a disconnect / reconnect again.
wds is my only option as there is only one radio in the slave- right? (2 in the mater btw; )
Looks to me like you have two “ap-bridge”…not a master and slave situation.
Have you tried the wds-slave and wds-station setting yet?
We’ve had lots of problems with disconnects and no beacon issues as well…and never been able to completely narrow the problem down.
Periodic calibration seemed to correct it most of the time, but not completely.
SMA
Well now it seems to be resetting MANY TIMES AN HOUR. This is such a problem… Its my understanding that you can have both points in AP mode, acting as a repeater as long as WDS mode is on. I was told that setting a unit to WDS slave or wds station is not a good idea. Plus i was getting resets like this as well and was told to switch from wds station to just station..
Why cant we get an official response on this? It seems to be a problem for ALOT of people as seen through the threads.
Im fine with one disconnect a day, but this is un acceptable for me and my customers…this is hourly now..
Does ANYONE have a WDS setup with minimum disconnects / resets and can post their wlan configs.
here is what i get in the logs:
06-23-2006	09:53:57	wireless,debug 2nd--: wlan1: created WDS link 00:02:6F:3D:90:74, name
06-23-2006	09:53:57	route,event 2nd--:     Interface
06-23-2006	09:53:57	route,event 2nd--: Link up
06-23-2006	09:53:57	route,event 2nd--: Up
06-23-2006	09:53:57	wireless,info 2nd--: 00:02:6F:3D:90:74@wlan1: connected, is AP, wants WDS
06-23-2006	09:53:57		wireless,debug 2nd--: wlan1: AP 00:02:6F:3D:90:74 not matched by connect-list, by default accept
06-23-2006	09:53:57	wireless,debug 2nd--: wlan1: 00:02:6F:3D:90:74 attempts to connect
06-23-2006	09:53:55	wireless,info 2nd--: wlan1: data from unknown device 00:02:6F:3D:90:74, sent deauth
2nd is the master that is wired and has 2 radios
tks
bump:
if anyone is using wds as a method of bridging to a repeater (ie. bridging and serving wifi customers) can you please post your settings or if you are having problems with disconnects.
thanks
I think your radio cards are causing you problems. I’ve seen a lot of posts with people having problems when using the new Senao radios…
