I’m trying to configure a wireless interface with mode=wds-slave. The SSID in question uses EAP-TLS, and I’d like the WDS slave to pass EAP requests to a Radius server (eap-methods=passthrough). But it seems that in order for the WDS slave to authenticate itself to the network, eap-methods needs to be set to eap-tls, in which case, the WDS slave will process EAP-TLS locally instead of using a Radius server.
Am I missing something here? Is it possible to achieve what I want (i.e., WDS slave on EAP-TLS SSID with a Radius sever)?
Thanks!
Alex
