WDS through ethernet
hi,
is it possible with CRS125-24G and RB951Ui-2HnD setup wifi network with one SSID?
Currently, CRS125 is switch and wifi AP and we bought RB951, which is planned to mount in part of our offices without wifi signal from CRS125.
I presume that i need WDS but those two routers should be replicated over ethernet.
I hope that i managed to explain ok my situation.
cheers!
No need for wds. Just run wire between the devices, set the new ap in the same way as the old one (only with non overlapping frequency) remove the rest of the configuration and bridge all ports together. Your clients will roam automatically.
Lol! Simpliest sollution at its finest!!!
Thx saving me not to overengineer stuff!!! :smiley:
Glad I could help you.
