Ok. I am drawing a blank. I’ve search over thru forum, and evidently haven’t found the right combination of keywords to find a solution.
I’m looking to connect multiple AP’s together thru WDS. I think it is the only achievable way to do what I am attempting, without adding more adjacent channel CPE’s or AP’s. I tried just putting them in AP Bridge, and assigning them to a Dynamic WDS thru bridge1, but it just connects and disconnects, as if it doesn’t authenticate. I’m not using anything other than WPA-PSK. All 3 ends have the same keys.
I need this to make one AP see another, when both need to have clients on them as well. I don’t have the ability to use multiple links thru these as each of them already have another link attached for another sector.
Interface 1 is the one I am trying to use WDS with. It can see one of the other AP’s just not the second AP it needs to connect to, with any consistancy.
ok. So it looks like I got the links to be solid. I had to disable WPA as well as increase my signal headroom.
However now I am experiencing another issue… My throughput has dropped to less than 500k. I can run TP tests from some of the CPE’s to the AP’s and get 7-8MB. but when I try and go thru one of the WDS Repeaters, it kills it. Either WDS repeater gives me the same problem.
I am using Dynamic WDS all are assigned to Bridge1 and I’ve turned security off on all of these links to simplify it for now.
The CPE’s are using Station WDS mode, and also have the WDS Tab set so it is assigned to Bridge1 and Dynamic.
Hopefully someone can see what i’ve done wrong. Other than I know it’s not a Routed solution! In my system I cannot make them as such, since I simply carry traffic for our IT department, and don’t manage the network itself.
please post configs of the AP , Stations and the repeaters too. You are having 2 radios on the same board or one radio does both the repeating and as AP too. My advise if you can avoid WDS please do. Just do the PTP with one radio and AP with an alternate radio
