WDS - Torch and PCQ problem
I have a WDS link (dynamic) and I run some traffic over it. When I try to torch interface wds, it shows all the traffic. But when I try to torch wlan1 interface (the real interface on AP), it does not show any traffic. In the Interface window in winbox, I can see, that the traffic is normally going through wlan1. I’m using 4.16 ROS. Why is it so?
And more:
When I create a Queue tree queue, assign parrent wlan1 and select queue type pcq (all four classifiers), it shows only one queue is actually created even if the classifier should divide it into say 5 queues. If I try the same setup without WDS, it works fine. Why is it so? Does WDS do some kind of packing IP packets?
