I’m trying to connect two mikrotik routers. In MT manual the WDS is discribed:
[WDS (Wireless Distribution System) allows packets to pass from one wireless AP (Access Point) to another, just as if the APs were ports on a wired Ethernet switch. APs must use the same standard (802.11a, 802.11b or 802.11g) and work on the same frequencies in order to connect to each other.]
I’ve tryed to do it by the manual… But no succes. Bouth routers see each other, I made WDS connection, bouth routers connect to each other buth no packets are getting throu.
Configuration of 1st router:
[admin@MikroTik router] interface wireless wds> print
Flags: X - disabled, R - running, D - dynamic
0 R name=“wds TEST” mtu=1500 mac-address=00:90:4B:FB:xx:xx arp=enabled
disable-running-check=no master-interface=wlan1
wds-address=00:02:6F:35:xx:xx
[admin@MikroTik router] interface wireless> print
0 R name=“wlan1” mtu=1500 mac-address=00:90:4B:FB:xx:xx arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name=“wireless one” mode=ap-bridge ssid=“A-l-i-e-n wireless 1”
area=“” frequency-mode=manual-txpower country=no_country_set
antenna-gain=0 frequency=2412 band=2.4ghz-b/g scan-list=default
rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic
wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=yes allow-sharedkey=no
Configuration of 2nd router:
[admin@MikroTik] interface wireless> print
0 R name=“wlan1” mtu=1500 mac-address=00:02:6F:35:xx:xx arp=reply-only
disable-running-check=no interface-type=Prism prism-cardtype=200mW
radio-name=“00026F353xxx” mode=wds-slave ssid=“A-l-i-e-n wireless 1”
antenna-gain=0 frequency=2412 band=2.4ghz-b scan-list=default
basic-rates-b=1Mbps max-station-count=2007 tx-power-mode=default
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
disconnect-timeout=3s on-fail-retry-time=100ms compression=no
allow-sharedkey=no
[admin@MikroTik] interface wireless wds> print
0 R name=“wds TEST” mtu=1500 mac-address=00:02:6F:35:xx:xx arp=enabled
disable-running-check=no master-interface=wlan1 wds-address=00:90:4B:FB:xx:xx
I allso tryed to connect one mikrotik router and one Dlink acces point DWL900AP+. There were the same resoults… no data didn’t came throu.
When I coonected my notebook to acces point I couldn’t connect to PPPoE server on router, hotspot also didn’t work. If I connect my notebook to router PPPoE and Hotspot work OK!..
What is wrong with my settings???
Thanx for the help!!
