I configured a WDS on 2 MTs without Nstreme… It worked having both MTs in AP mode with WDS activated… But I would really want is to try out Nstreme (it’s the reason why I bought the routeros in the first place)…
When I activate Nstreme on this WORKING WDS it stops doing so… I read the manual and it says that for WDS to work with Nstreme I should have one of the MTs on STATION WDS mode… I tried it and it keeps roaming… If I try both in AP mode they just dont do anything… No log, etc… If I disable the Nstreme on one of them, it finally tries to connect on the WDS but argues about the other AP asking for Nstreme…
So… I’m quite lost… It works perfectly if I don’t use Nstreme…
Here’s what I get on the log, even with the changes you said:
19:34:44 wireless,debug wlan1: STA starts scanning
19:35:01 wireless,debug wlan1: STA scan over, results:
19:35:01 wireless,debug 00:02:6F:47:E7:92: on 5200 SSID caps 0x421 rates
0xff00 basic 0x100 MT: yes
19:35:01 wireless,debug wlan1: must select network
19:35:01 wireless,debug wlan1: no network that satisfies connect-list, by
default choose with strongest signal
19:35:01 wireless,debug wlan1: failed to select network
19:35:01 wireless,debug wlan1: STA starts scanning
