We have lost the password !!!!!!!!!!
We have lost the password for RouterOS !!!
How to get a password lost ???
reinstall and reset all config
Is there a password Comprehensive of RouterOS ???
Passwords can’t be recovered from ROS.
If you forgot it, you reinstall it unfortunately.
oh,............my GOD
regards
BalimoreDOTcom
Not RouterOS’s fault if you can’t remember your password :confused:
Not RouterOS’s fault if you don’t backup your configurations (which would make a reset no big deal at all really) :confused:
What’s the problem here? :slight_smile:
Have you installed your RouterOS with the lost password on a CF or harddisk?
Or is it a Routerboard with RouterOS installed in flash?
seandsl
