web access impossible
Using Dude3.0 last version downloaded today.
Web access impossible. I verified firwall - port open.
Any idea ?
I have checked my 3.0 Dude, web server is working fine.
Do you have web server enabled in the Dude ?
Hi
My web access on secure port work fine for me.
It’s upgrade from 3.0RC3 to 3.0
Try maybe with local access first, after upgrade first login is failed.
/jfvp
I still don’t understand how to access this Web Server.
I have activated it but I haven’t found the way to access it.
Can you explain me how to do this ?
http://x.x.x.x
or
https://x.x.x.x:xx
if your server is named in dns use it by name
http://thedude
I changed from 443 to 444 for secure since CiscoWorks is on the same server.
https://thedude:444
I use 8080 and 8443 (because I’m running on a Win2003 server and 80 is already used by IIS)
http://myserver:8080
or
https://myserver:8443
Thanks for all answers. Web access enabled. Using Windows Server 2003.
http port 3306 and https 443.
It doesn’t work locally.
Always searching…
Regards,
Posh
Works locally now after installing IIS. Great !
Now remotly…
All works, I used a bad port. Thanks a lot for your help.
Thanks for this software too.
Posh
Thanks for your help :slight_smile:
