Hello everyone,
I would like to know if there is a way to have-setup Web Access in Dude Server 6.45.7.
I have it on a RB750gr3 Hex device and i want to be able to access it from any network for monitoring purposes.
Any help is appreciated!!!
Web access to the dude is pretty limited, but possible.
Just log into webfig of your hEX and navigate to Dude.
It’s totally OK to view network maps which already have been created - but not much more.
It might be a good idea to create a separate user for this together with a custom skin.
-Chris
cdiedrich i got the idea, thank you for your reply.
I did that and made a user with only read permission.
Is there a way to only show the network maps and not all the other features?
Maybe you have a custom skin and have Dude menu blocked. https://myrouter/webfig/#Dude will return you to the Quickset, you have include :Menu_Name. Such as https://myrouter/webfig/#Dude:Network_Maps
[quote=kennnnnnnneth post_id=852258 time=1617822240 user_id=184396]
Screenshots attached
[/quote]
kennnnnnnneth, please let us know the device model you are using here.
Maybe you should a netinstall. I had a new hEX S that was in a boot loop from the box. I preformed a netinstall and it has been fine since.
