I use web access to monitor my network. Everything works fine during 2 or 3 days, after that time Dude stops displaying the maps on the web page. I need to disable and enable web access in the server configuration to make it work once again, for few more days…
I have this problem with all v.3 beta of Dude.
thx
Hi guys,
I recognize this problem.
Something similar occurs here.. I’ve 21 charts with a little over 42 data sources which should graph values. Now I’m used to occasional gaps within graphs, but within the webserver graphs occasionally disappear completely to never return back.. Within the Dude (3b6) itself I can access the graphs normally.
Within Dude 3b6 it’s also the case that you sometimes see a link to charts within the webserver, but when clicking this link you sometimes won’t see any graph at all.
Anyone with a workaround and/or solution for this?
Regards,
Minollie
