I have just started to use a CCR-1036 and i decided to start of with a simple config and build up from there.
My config is as follows.
eth1 is connected to bridge one.
bridge one is a DHCP client and gets an ip address of 192.168.15.82
eth8 is connected to bridge8 and it runs a DHCP server
I am NOT using NAT and I am not using any firewall.
I have the following static route setup on my internet gateway so i can receive incoming/returning traffic.
dest = 192.168.108.0/24 gateway = 192.168.15.82
when i plug a pc into eth8 and get an ipaddress, i can successfully ping www.google.com.au from the pc command line
BUT if i go into my pc's browser, I am unable to connect to the website.
While investigating this, I turned on the web proxy and sent my browser through it...and it all worked and i could open the webpage.
Could someone please look at my config below and tell me what i may be missing to have web access without the web proxy enabled?
Thanks for your help
Stuart
jun/10/2016 11:19:49 by RouterOS 6.35.2
software id = WWZ0-L2UF
add name=port1Bridge
add name=port8Bridge
add name=dhcp_pool1 ranges=192.168.108.1-192.168.108.253
add address-pool=dhcp_pool1 disabled=no interface=port8Bridge name=dhcp1
relay=192.168.108.254
add bridge=port8Bridge interface=ether8
add bridge=port1Bridge interface=ether1
add address=192.168.108.254 interface=port8Bridge network=192.168.108.254
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no
interface=port1Bridge
add address=192.168.108.0/24 dns-server=192.168.15.1 gateway=192.168.108.254
set allow-remote-requests=yes servers=8.8.8.8
/ip proxy
set anonymous=yes enabled=yes
add distance=1 dst-address=192.168.15.82/32 gateway=port1Bridge
add distance=1 dst-address=192.168.108.0/24 gateway=port8Bridge
/system clock
set time-zone-name=Australia/Sydney
/system logging
add topics=web-proxy
/system routerboard settings
set cpu-frequency=1200MHz memory-frequency=1066DDR protected-routerboot=
disabled
