web and mail server on the network.
Hi
I am using 3011 router and is setting it up, I have internett on all my stuff so that part works great, I have also made a separate network for my server that host web and mail server.
The server is running is own firewall so I just want to dmz the server, how can I do that?
Here is my config.
apr/15/2021 12:00:34 by RouterOS 6.49beta27
software id = 61BP-NFIR
model = RB3011UiAS
serial number = E14E0D97D028
add name=local
add name=server
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.88.2-192.168.88.254
add name=dhcp_pool1 ranges=192.168.150.2-192.168.150.254
add name=dhcp_pool2 ranges=192.168.150.2-192.168.150.254
add address-pool=dhcp disabled=no interface=local name=dhcp1
add address-pool=dhcp_pool2 disabled=no interface=server name=dhcp2 relay=
192.168.150.1
add bridge=local interface=ether2
add bridge=local interface=ether3
add bridge=local interface=ether4
add bridge=local interface=ether5
add bridge=server interface=ether6
add interface=ether1 list=WAN
add interface=local list=LAN
add address=192.168.88.1/24 interface=local network=192.168.88.0
add address=192.168.150.1/24 interface=server network=192.168.150.0
/ip dhcp-client
add disabled=no interface=ether1
add address=192.168.88.0/24 dns-server=1.1.1.1 gateway=192.168.88.1
add address=192.168.150.0/24 dns-server=1.1.1.1 gateway=192.168.150.1
add action=accept chain=input comment="accept established,related"
add action=drop chain=input connection-state=invalid
add action=accept chain=input comment="allow ICMP" in-interface=ether1
protocol=icmp
add action=accept chain=input comment="allow Winbox" in-interface=ether1
port=8291 protocol=tcp
add action=accept chain=input comment="allow SSH" in-interface=ether1 port=22
protocol=tcp
add action=drop chain=input comment="block everything else" in-interface=
ether1
add action=dst-nat chain=dstnat dst-port=80 in-interface=ether1 protocol=tcp
to-addresses=192.168.150.100
/system clock
set time-zone-name=Europe/Oslo
Do I need to move the last rule up?
Best regards
The newbie
What do you mean you want to DMZ the server?
Did you mean you want others to be able to use the server that are coming from the internet (port forwarding??)
HI
This is my web server that host many sites, and I am running a mail server on it to. I want the server open to the net so people can see the pages and mail will be passed as it did before.
It has been a long time since i did any microtik configs so i dont remember what I did to make it work back then. I have done some changes but it did not work... I put the server on a different network as this is the best practice. But I would like to RDP into it from my main network.
Here is the changes I did.
apr/15/2021 13:57:24 by RouterOS 6.49beta27
model = RB3011UiAS
add name=local
add name=server
add name=WAN
add name=LAN
add address-pool=dhcp_pool1 disabled=no interface=server name=dhcp2
add interface=server list=LAN
/ip dhcp-client
add address=192.168.150.0/24 gateway=192.168.150.1
add action=fasttrack-connection chain=forward connection-state=
established,related
ether1
add action=accept chain=forward connection-state=established,related
add action=accept chain=input connection-state=established protocol=tcp
add action=accept chain=input dst-port=22 in-interface=ether1 protocol=tcp
add action=accept chain=input src-address-list=local
add action=accept chain=input src-address-list=server
add action=dst-nat chain=dstnat comment="And the rest goes to the DMZ host"
dst-port=1024-65535 in-interface=ether1 protocol=tcp to-addresses=
192.168.150.100 to-ports=80-65535
dst-port=80-65535 in-interface=ether1 protocol=udp to-addresses=
add action=netmap chain=dstnat dst-address=my wan ip/24 to-addresses=
192.168.150.0/24
/system clock
(1) Don;t need two bridges and although i normally recommend vlans for most cases you dont need those either.
add one-bridge
add name=WAN
add name=LAN
add address-pool=dhcp disabled=no interface=one-bridge name=dhcp1
add address-pool=dhcp_pool1 disabled=no interface=ether6-server server name=dhcp2
add one-bridge interface=ether2
add one-bridge interface=ether3
add one-bridge interface=ether4
add one-bridge interface=ether5
add interface=one-bridge list=LAN
add interface=ether6-server list=LAN
add address=192.168.88.1/24 interface=one-bridge network=192.168.88.0
add address=192.168.150.1/24 interface=ether6-server network=192.168.150.0
/ip dhcp-client
add address=192.168.150.0/24 gateway=192.168.150.1  dns-server=192.168.150.1
(2) This rule has no business on the config… as its a huge secuirty risk
.add action=accept chain=input comment=“allow Winbox” in-interface=ether1
USE VPN to access the router from the WAN side. and dont use the default winbox port…
(3) FIREWALL RULES NEED A TON OF WORK
Because you have a drop rule at the end of your input chain, before you remove the above rule PUT IN PLACE the actual required rule to
access the router for the admin person on the LAN.
Ex.
add chain=input action=allow in-interface=one-bridge source-address-list=adminaccess
WHERE
/ip firewall address list {assuming these have been statically set/fixed}
add address=ip of admin desktop list=adminaccess
add address=ip of admin laptop list=adminaccess
add adddress=ip of admin smartphone list=adminaccess
(4) THis rule does nothing…
(5) THIS rule is duplicated
(6) This rule is not required to permit FTP traffic from the WAN to the LAN side (server) etc…
(7) These rules are FAR TOO WIDE especially for the server side, NO one or devices need full access to the router, only the admin does and the rule stated above in (3) handles that requirement.
Instead, delineate ONLY the services that users need, and in this case I suspect its only for DNS services??
add action=accept chain=input comment=“Allow LAN DNS queries - TCP”
connection-state=new dst-port=53 in-interface-list=LAN protocol=tcp
add action=accept chain=input comment=“Allow LAN DNS queries-UDP”
connection-state=new dst-port=53 in-interface-list=LAN protocol=udp
(8) This rule is duplicated
(9) Missing any sort of drop all from forward chain or drop all not dst-natted!!! (thus no security on LAN from WAN very bad!!!
(10) Missing any rule allow port forwarding
(11) ORDER and clarity Matters within firewall filter chains!
add action=accept chain=input comment="accept established,related" \
add action=accept chain=input comment="Allow ADMIN to Router" \
    in-interface=one-bridge src-address-list=adminaccess
add action=accept chain=input comment="Allow LAN DNS queries - TCP" \
add action=accept chain=input comment="Allow LAN DNS queries-UDP" \
add action=drop chain=input comment='Drop all else'
add action=fasttrack-connection chain=forward connection-state=\
established,related
add action=accept chain=forward comment="allow homelan to WAN traffic" \
     in-interface=one-bridge out-interface-list=WAN
add action=accept chain=forward comment="allow server to WAN traffic" \
     in-interface=ether6-server out-interface-list=WAN
add action=accept chain=forward comment="allow admin to server traffic"
     in-interface=one-bridge source-address-list=adminaccess out-interface=ether5-server
add action=accept chain=forward comment="Allow Port Forwarding" connection-nat-state=dstnat \
add action=drop comment="drop all else"
(12) NAT rules… not sure the purpose of your netmap rule so would get rid of it for now…
Also I am not sure in blocks of ports how its handled by the router and I think your setup will NOT work.
For example, for the TCP first rule, these are non-matching block 1024-65535 translated to 80-65535.
To put this in perspective it is not clear to me how the router would handle traffic coming over (5 ports) dst-ports 5-10 translated to ports 8-10 ?
Clearly the router would run out after 2 incoming ports had been assigned/translated.
Also note that its not a direct sequential 1:1 translation either, 1024 does not get assigned necessarily to 80 and so forth
WHY are the UDP and TCP port assignments different???
Thank you so much, I will take some time to study and do as you say tonight, I think Mikrotik has a very good system and I want to learn as much as I can. Thank you for your guide.
