Hi all.
I´m new to MIKROTIK world and I´m not a network profesional, but I try to do the best I can.
I have a RB951G - 2Hnd ROUTER,
My ISP is TELEFONICA in Spain. As far as I know it uses a pppoe server and 2 VLAN to bring me FTTH internet and TV services,
My config is :
add name=bridge-local
/interface wireless
#set 0 band=2ghz-b/g/n country=spain disabled=no ht-rxchains=0,1 ht-txchains=\
# 0,1 tx-power=17 tx-power-mode=all-rates-fixed mode=ap-bridge \
# wireless-protocol=802.11
set 0 band=2ghz-b/g/n country=spain disabled=no rx-chains=0,1 tx-chains=0,1 tx-power=17 tx-power-mode=all-rates-fixed mode=ap-bridge wireless-protocol=802.11
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
/interface vlan
add interface=ether1-gateway name=vlan3 vlan-id=3
add interface=ether1-gateway name=vlan6 vlan-id=6
/interface pppoe-client
add add-default-route=yes allow=pap,chap disabled=no interface=vlan6 \
max-mru=1492 max-mtu=1492 name=pppoe-out1 password=adslppp \
use-peer-dns=yes user=adslppp@telefonicanetpa
set [ find default=yes ] authentication-types=wpa2-psk group-ciphers=\
aes-ccm mode=dynamic-keys unicast-ciphers=aes-ccm \
wpa-pre-shared-key=mikrotik wpa2-pre-shared-key=mikrotik
add name=dhcp ranges=192.168.1.201-192.168.1.249
add name=vpn ranges=192.168.3.10-192.168.3.20
add address-pool=dhcp disabled=no interface=bridge-local name=dhcp1
/ppp profile
set 1 dns-server=192.168.3.250 local-address=192.168.3.250 remote-address=vpn
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
/interface pptp-server server
set authentication=mschap2 enabled=yes
add address=192.168.1.1/24 comment="default configuration" interface=wlan1
add address=192.168.100.10/24 interface=ether1-gateway
/ip dhcp-client
add add-default-route=no disabled=no interface=vlan3 use-peer-ntp=no
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1 \
netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add chain=input disabled=yes dst-port=23,80 in-interface=pppoe-out1 protocol=\
tcp
add chain=input dst-port=8291 in-interface=pppoe-out1 protocol=tcp
add chain=input dst-port=1723 in-interface=pppoe-out1 protocol=tcp
add action=drop chain=input comment="default configuration" in-interface=\
pppoe-out1
add chain=forward comment="default configuration" connection-state=\
established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
/ip firewall mangle
add action=set-priority chain=postrouting new-priority=4 out-interface=vlan3
add action=set-priority chain=postrouting new-priority=1 out-interface=\
pppoe-out1
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=pppoe-out1
out-interface=ether1-gateway
out-interface=vlan3
add action=dst-nat chain=dstnat disabled=yes dst-port=80 in-interface=\
pppoe-out1 protocol=tcp to-addresses=192.168.1.125
add action=dst-nat chain=dstnat disabled=yes dst-port=21 in-interface=\
add distance=255 gateway=255.255.255.255
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge-local type=internal
add interface=pppoe-out1 type=external
/routing rip interface
add interface=vlan3 passive=yes receive=v2
/routing rip network
add network=10.0.0.0/8
/system clock
set time-zone-name=Europe/Madrid
/system ntp client
set enabled=yes primary-ntp=163.117.202.33 secondary-ntp=\
89.248.104.162
My question is simple: What I´m doing wrong because some web pages does not load or not properly and, why iTunes does not work at all???
I know there is lots of people with this config that does not have any problem at all .
DNS problems?? Apple problems ??
Thank you in advance to anyone who could help me.
