Router 951G, the provider on PPPoE, gives under the tariff 50 Mbit, on resources yandex, the same mirror.yandex.ru - on it gives 100 Mbit.
If to switch out a proxy then is 100 Mbit gallop of a file by several streams, with included exactly 50 Mbit
That is it is gained if to swing one file with mirror.yandex.ru in some streams all streams transforms a proxy into one stream, this bag or not?
Google translate:
Router 951G, provider on PPPoE, gives at the rate of 50 Mbit, resource yandex, the same mirror.yandex.ru - it gives 100 Mbit.
If you turn off the proxy, then there is a 100 Mbit download the file more than one thread included exactly 50 Mbit
That is, it turns out, if one download file mirror.yandex.ru in several streams, the proxy converts all streams into a single stream, this bag or not?
RouterOS 6.7
Sory, my inglish is bad, a im russian
