Web Proxy Cache and DNS Cache without Hotspot
When using the Hotspot function, Web Proxy Cache and DNS Cache work fine. However, when the Hotspot is turned off, no data get cached. What do I need to do to use cache without the Hotspot? We are using an RB433 with ROS v3.22.
You need to add a dst-nat rule to redirect port 80 traffic to your proxy port
Thank you skillful! It worked fine.
