Hi all,
I’m using MT Rc2 on a SATA disk.
It’is possible to have the Web proxy cache on the same system
sata disk ?
when i try to format or check drive i got an error.
Thank you.
Rgr
Pascal
Hi all,
sata disk ?
Thank you.
Rgr
Pascal
Yes, it is possible to cache on disk, you do NOT need to format drive (it is already formatted apropriately, as RouterOS is running on it),
set ‘ip proxy set cache-drive=system cache-on-disk=yes’.
Bonjour Sergejs,
Yes i have seen with this setting that it was working as i saw a lot of
disk activities when browsing the internet.
Anyway thank’s for your answer.
Rgr
Pascal
