web proxy error
i need help, have routeros x86 3.1 webproxy enabled and found this:
web-proxy error stat(´var/cache/e/10/e1096999319d7f4cf10d6fef265f05b7´) failed:Input/output error
system unstable and fix temporary disable weproxy.
Any have this problem??
thanks
Yes, i have this problem in 3.3. I sent an supout to the support, but no reply up to now. Tip: check your hard drive and try upgrade to 3.2
Check your HDD > /system check-disk
I had that kind a problem too and I done check disk then it was solved.
