I’ve been seeing these type of errors lately in my log from the web proxy. Can someone explain to me the significance of them?
Thanks in advance,
-tp
Thanks in advance,
-tp
Format your proxy drive.
The Proxy Drive had been previously formated correctly. The errors in the log that I have illustrated occur about once a day. When they do occur, I take the proxy-drive SD card offline, and have the RB reformat it. It does not seem to matter, as the error occur eventually again. I have tried two different microSD cards with the same result. The cards all seem to function well, but eventually the errors show up. I get the same results running the RB433AH at 680 MHz or at 800, no difference. I’m currently using ROS v3.18 (2.18) but saw the same errors using 3.17.
-tp
PS: Does anyone know when the next MUM will be in the USA? ![]()
e-mail a supout.rif to support@mikrotik.com explainign the problem/pointing to this topic.
it could mean nothing, if there are no other problems except this entry.
what do you see in following:
/strore disk print
/ip proxy monitor once
same problem for me…
currently i use 3.17 . I noticed that when this happens, automatic stop redirection from ip firewall nat, the clients lose conection, and the queue are freeze, for which is necessary to do a reset. After I restart, it is necessary to disable the proxy and the redirection in order that the queue limit again. identically issue on 3.13. Regards
What’s new in 3.19:
*) fixed problem - web proxy used up all router memory
if unlimited ram caching was enabled;
Install v3.20/or the lastest/ and try again ![]()
Also have a look at this: http://forum.mikrotik.com/t/interface-stats-and-cpu-usage-not-correct-after-upgrade/24752/24
Hey keep us informed of the issue and the solution ![]()
i have 3.20 and http proxy freezes, no browsing no internet but there is ping. internet works untill i disable and then re-enable it again to make internet work. :S plz this is a problem with many people.
At one of the sites on a RB433AH ROS v3.20/mipsbe I can see that 10GB web traffic has passed through the proxy in 5 days uptime, with 120MB hits sent to clients, and nobody has called in a problem and it seems to be working fine, when I check it out in WinBox. But maybe my config is good.
Since v3.20, no problems. Everything seems to be running great.
-tp
