Web proxy generate 100 % CPU
Web proxy generate 100 % CPU after 5-15 minutes from boot up on RB493. Web proxy service himself use 98 % as shown in profiles.
Restore from backup .. even with 2-3-4 steps ahead .. and same behavior.
this was happening on 5.26. Even after downgrade to 5.25 same thing.
any suggestion for solving the problem ?
how can I investigate this ? where can be seen what sites actually access the users ?
Proxy on a 493 is probably too much for it to handle.
Go to IP > Web Proxy.
What are Parent Proxy, Max Cache Size and Cache on Disk set to?
Click Cache Contents button.
Users access any site they want !
I thought maybe you were running the proxy on the 493 itself, without parent proxy, and that could cause high cpu.
No. If you’re using parent proxy, I don’t know if this would even matter…
After upgrading to 6.5 … after setup Max Cache to 20000 KiB … on RB450 and RB493 (setup to 5000 on RB750) … the machines works normal. Web proxy are using 0.5-10 % CPU.
For curiosity I setup max Cache to 30000 KiB and choose Cache to Disk … but this generate bigger fluctuation 10 - 75 % CPU and this makes overall CPU load to 100 % and makes machine slow responsive !
So .. it is not the same to Cache on DISK or Cache on Ram :slight_smile:
Now is clear ! I do not know why someone who read not said so … probably others do not test it themselves :slight_smile:
