Web-Proxy Max-object-zise
It would have as to modify the size of the Max-Object-Size of web-proxy MK3.
Dear ;
you mean that you want to change the max object size in the proxy ? ,
could you put a photo to the web proxy interface you have ? .
with best regards
hi
i just setup router os on my machine for my own network and i got 5pc on my network i would like to use as a proxy server to give 5users strong and fast internet connection how could i do this ? please help
This will show you what you need to have plus a bit more if you want to block some content.
http://wiki.mikrotik.com/wiki/How_to_Block_Websites_%26_Stop_Downloading_Using_Proxy
-Louis
thanks for your reply i am glad to have a reply and i am not a expert user so could you please explain to how will i open the proxy options and will cache all traffic..
Hi ;
thanks for your reply .
before i read the link above let me ask if i could make the cache store the files like mp3 . mpeg , avi , exe , etc. .
this will help a lot to reduce the number of downloading same song or file from the internet
and i hope this will improve the internet speed .
with best regards .
By default the proxy will cache everything it can including all those file types you mentioned. You will need to complete the first 3 sections. The rest is optional.
-Louis
thanks for your suppert
what will be the first 3 step please ?
bilgin@hotmail.co.uk
Follow the instructions on the link I posted for you. Look up.. You even quoted me with it. :slight_smile:
-Louis
