web proxy - No buffer space available
I am running RouterOS 5.6 on x86. The pc is a Pentium 4 2.8ghz with 1Gb Ram and 80GB Hard Disk Drive. When web proxy is active I get a mesaage on my web browser after a while saying No buffer space available.
Has anyone had this problem and how do I solve it?
Thanks.
Please make screenshot from your browser during the problem and post it here.
Here is a screenshot
I have my web proxy setup to (max. cache size: unlimited) and cache on disk enabled. Max client connections and server connections is set at 600, max fresh time is 3 days. In firewall NAT i redirect all port 80 traffic to the proxy on 8080.
[admin@Hotspot-Server] /ip firewall nat> print
 0   ;;; place hotspot rules here
     chain=unused-hs-chain action=passthrough
 1   ;;; masquerade hotspot network
     chain=srcnat action=masquerade src-address=192.168.30.0/24
 2   ;;; masquerade hotspot network
     chain=srcnat action=masquerade src-address=192.168.32.0/24
 3   ;;; PPPoE
     chain=srcnat action=masquerade src-address=10.0.0.0/24
 4   ;;; Proxy
     chain=dstnat action=redirect to-ports=8080 protocol=tcp dst-port=80
add number 4 to your NAT
[admin@Hotspot-Server] /ip firewall mangle> print
 0   ;;; Accept Proxy
     chain=output action=accept dscp=4
 1   ;;; ping
     chain=prerouting action=mark-packet new-packet-mark=ping_requests passthrough=yes protocol=icmp
 2   ;;; QoS OF PING
     chain=postrouting action=mark-connection new-connection-mark=ping-ip passthrough=yes protocol=icmp
 3   ;;; QoS OF PING
     chain=postrouting action=mark-packet new-packet-mark=packet_ip passthrough=yes connection-mark=ping-ip
((chain=output action=accept dscp=4 )) must be the first one in mangle
then
[admin@Hotspot-Server] /ip proxy> print
                 enabled: yes
             src-address: 0.0.0.0
                    port: 8080
            parent-proxy: 0.0.0.0
       parent-proxy-port: 0
     cache-administrator: "Skynet Hello..!! reload your page"
          max-cache-size: unlimited
           cache-on-disk: yes
  max-client-connections: 1000
  max-server-connections: 1000
          max-fresh-time: 1d
   serialize-connections: no
       always-from-cache: yes
          cache-hit-dscp: 4
             cache-drive: primary-master
then tell me :slight_smile:
I have made the changes you suggested. I will let you know what happens, thanks. :smiley:
Still getting the same message, here is a screenshot of the server status
well !!!
print
/ip proxy> print
[root@Load Balancer] > ip firewall nat print
0 X ;;; proxy
1 chain=srcnat action=masquerade
2 chain=dstnat action=dst-nat to-addresses=192.168.10.20 to-ports=8081 protocol=tcp dst-port=8081
3 chain=dstnat action=dst-nat to-addresses=192.168.10.110 to-ports=8082 protocol=tcp dst-port=8082
4 chain=dstnat action=dst-nat to-addresses=10.0.0.249 to-ports=2210 protocol=tcp dst-port=2210
[root@Load Balancer] > ip firewall mangle print
0 ;;; accept proxy - no limits
[root@Load Balancer] > ip proxy print
enabled: yes
port: 8080
cache-administrator: webmaster
cache-on-disk: yes
max-fresh-time: 1d
cache-hit-dscp: 4
i think :slight_smile:
in ip firewall nat you need to move
0 X ;;; proxy
down
and check
[admin@Server] /store>
then check your firewall too maybe you need some new settings in firewall when you using Load Balance
and you can send e-mail the support in finally
sorry that is all i have help
:smiley: Thanks for the help, I will try it and if I get it working I will post it on here.
