web proxy not working
ok if i try connecting a single pc to my proxy and specify internet explorer to connect directly to it it works if i enable my rule taht redirects all tcp 80 traffic to port 8080 on the same mikrotik box it does not work it just stoped working without any reason??? how the hell does that happen with mikrotik???
it looks like it crashes for some reason when i enable the redirect rule?
here is how my nat looks like:
0 chain=srcnat action=masquerade
1 X ;;; REDIRECT-ALL-TO-PROXY
chain=dstnat action=redirect to-ports=8080 protocol=tcp
in-interface=ether3-crazywifi dst-port=80
2 X ;;; PPTP-VPN-RULE
chain=srcnat action=masquerade src-address=172.16.0.0/24
3 ;;; tony parradox
chain=dstnat action=dst-nat to-addresses=192.168.29.120 to-ports=999
protocol=tcp in-interface=mweb dst-port=999
4 ;;; SSH
chain=dstnat action=dst-nat to-addresses=192.168.112.252 to-ports=22
protocol=tcp in-interface=mweb dst-port=22
5 ;;; ASTERRISK-SERVER-VOIP
chain=dstnat action=dst-nat to-addresses=192.168.1.11 to-ports=5060-5082
protocol=udp in-interface=mweb dst-port=5060-5082
6 ;;; ASTERRISK-SERVER-VOIP
protocol=tcp in-interface=mweb dst-port=5060-5082
7 ;;; ASTERISK-VOIP
chain=dstnat action=dst-nat to-addresses=192.168.1.11 to-ports=8000-20000
protocol=udp in-interface=mweb dst-port=8000-20000
8 ;;; DEBTSOLVER-VNC’S
to-ports=5900-5909 protocol=tcp in-interface=mweb dst-port=5900-5909
9 ;;; ARTHUR_BUITEKAMER_VNC
chain=dstnat action=dst-nat to-addresses=192.168.1.138 to-ports=5900
protocol=tcp in-interface=mweb dst-port=5911
10 ;;; ARTHUR_BUITEKAMER_VNC
chain=dstnat action=dst-nat to-addresses=192.168.1.121 to-ports=5900
protocol=tcp in-interface=mweb dst-port=5912
11 ;;; NASHED-AP
chain=dstnat action=dst-nat to-addresses=10.1.1.1 to-ports=8291
protocol=tcp in-interface=mweb dst-port=8292
12 ;;; INTERSPLITTER
chain=dstnat action=dst-nat to-addresses=192.168.1.1 to-ports=8291
protocol=tcp in-interface=mweb dst-port=8293
13 ;;; COREROUTER2
chain=dstnat action=dst-nat to-addresses=192.168.1.2 to-ports=8291
protocol=tcp in-interface=mweb dst-port=8294
14 ;;; MITCH-AP
chain=dstnat action=dst-nat to-addresses=192.168.1.3 to-ports=8291
protocol=tcp in-interface=mweb dst-port=8295
15 ;;; CHARLES HUIS AP
chain=dstnat action=dst-nat to-addresses=10.2.1.253 to-ports=8291
protocol=tcp in-interface=mweb dst-port=8296
16 ;;; MIND-CRAFT-DOMINIQUE
chain=dstnat action=dst-nat to-addresses=192.168.24.52 to-ports=25565
protocol=tcp in-interface=mweb dst-port=25565
– [Q quit|D dump|up|down]
