Hello All,
I need some help.
I have made web proxy and it seemed to work for a while but stopped working all together. I want to block all internet of all PCs except some website and some PCs (MAC addresses) will have open internet with no restriction.
Issue is, the specific websites that I need to open such as gmail etc, not open.
This is my complete code, please help
# may/22/2015 03:17:22 by RouterOS 6.24
# software id = MIFM-J9E5
add name=dhcp_pool1 ranges=192.168.0.100-192.168.0.250
add address-pool=dhcp_pool1 disabled=no interface=ether1 lease-time=8h name=\
add address=192.168.0.1/24 comment="default configuration" interface=ether1 \
network=192.168.0.0
add address=192.168.1.2/24 disabled=yes interface=ether11 network=192.168.1.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
interface=ether11
add address=192.168.0.0/24 dns-server=8.8.8.8,192.168.1.1 gateway=192.168.0.1
set allow-remote-requests=yes servers=8.8.8.8
add action=drop chain=input dst-port=8080 in-interface=ether11 protocol=tcp
add chain=dstnat comment="Admin PC" src-mac-address=00:21:9B:59:1C:EE
add action=jump chain=dstnat dst-port=80 in-interface=ether11 jump-target=\
http_proxy_check protocol=tcp
add action=return chain=http_proxy_check src-mac-address=5C:26:0A:82:0D:AC
add action=redirect chain=dstnat dst-port=80 protocol=tcp to-ports=8080
add action=redirect chain=dstnat protocol=tcp to-ports=8080
add action=redirect chain=dstnat protocol=udp to-ports=8080
/ip proxy
set max-cache-size=4096KiB parent-proxy=0.0.0.0
/ip proxy access
add action=allow dst-host=:gmail
add action=allow dst-host=:google
add action=allow dst-host=:fbr.gov.pk
add action=allow dst-host=:mail
add action=allow dst-host=:lesco
add action=allow dst-host=:tcscouriers
add action=allow dst-host=:sngpl.com.pk
add action=allow dst-host=:wapda
add action=deny dst-port=80
add distance=1 gateway=ether11
add disabled=yes distance=1 gateway=192.168.1.1
/ip upnp
set enabled=yes
Again, the issue is, either it blocks everything completely, or open completely for the specific MAC address I give it. I want only few sites to be opened but it doesnt.
IM STUCK
Please help
Regards,
Safiullah
