Is it a good idea to switch on Web Proxy on a RB1100?
Would it it that case be best to expand the RAM and use the system store, or to insert a SD card and use that as a separate store for the Web Proxy? Where is the NAND in the RB1100..? Is this the 512 MB built-in memory or something else..?
It would be best to add an SD card and use that as the proxy store. Adding more RAM may be valuable as your utilization may go up when enabling that feature. It should be the 512mb built-in memory. Not sure where its physically located. Its been a while since I’ve opened my 1100.
I'm a bit confused about the memory on the RB1100..
It should have 512 MB internal memory, but it some places it says it's SDRAM, and in others that this is a NAND (flash).
Mmmm.. you’re right. I should download the RB1100 user guide and read it myself, instead of asking silly questions..
In the wrong forum as well, apparently.. (no idea why I created this thread under Virtualization).
Anyway, I’ll try to enable Web Proxy in one of our production RB1100 routers and see what happens then..
