I have RB1100AHx4,I installed new 128GB SSD in.Please help me how I enable web proxy on SSD drive.
You need to first format the drive, (System > Disks), then set the folder is it mounted on on IP > Web Proxy (last parameter field, Cache Path).
For temporary basis my main router is RB2011 and RB1100AHx4 connected as a bridge with RB2011. I format HDD and enable proxy but that is not working.
Sent from my LG-H990 using Tapatalk
Have a look at https://wiki.mikrotik.com/wiki/Manual:IP/Proxy#Transparent_proxy_configuration_example
Bear in mind is it not possible to transparently proxying https traffic, which accounts for the majority of web traffic nowadays.
Don’t forget , the proxy on mikrotik it is not compiled to use multi core…
So if you use proxy the performance is very poor.
Regards
