hello,
i am directing all traffic on port 80 to 3128 (web proxy) and working fine.
i tried to setup a parent proxy to direct all the traffic to that proxy, it also worked fine.
now, this parent proxy requires authentication, so, whenever i click a page, i get a reply from the parent proxy that you must be authenticated, is there anyway to do the authentication from MT?
Thanks for your answer, i think the same thing…
How did you resolve it?
I need to log only the web traffic, but i want to be sure which is the user on the other side, so, the simple IP is not sufficent.
For this reason i setted up a squid with radius authentication, which on it’s log write:
user1, web sites, time, ecc…
How could i solve this?
I could setup an hotspot, but i don’t want to block all the traffic of my user, ONLY log visited web sites (by country local regulations).
I setted up a rule as (to try to bypass the MT proxy and to mantein only the squid proxy):
