I have problem with web-proxy. When I enable status is “passthrough” and dont working. As I know status must be “running”.
Can anyone help me?
Nobody can help me?
Did you set the dst-nat rule for rediecting traffic on destination port=80 to the 8080 port or not?
Yes but its still “passthrough”.
Where are you storing your Web Proxy? You need to select the designated storage drive from the Web Proxy. If that drive, within files, has lost & found in it, then delete the lost & found files and try again.
-tp
Thx, with 6.43.1 update its working fine.
