Web-Proxy Status Passthru
Hello, im implementing a X86 RouterOS running in a ESXi environment, it was working until i got a Level 4 license to run a transparent web-proxy.
When i enabled the web proxy it is giving me a status unknow, when i go to the terminal to check it gives status: passthru. This status isn´t documented, what gives this status?
I cannot get it to run.
Thanks!
This is my /ip proxy expor hide-sensitive
/ip proxy
set cache-administrator=suporte@facuryepalma.com.br enabled=yes \
    max-cache-size=none parent-proxy=0.0.0.0 src-address=192.168.1.1
/ip proxy access
add comment=SERPRO disabled=yes dst-address=161.148.0.0/16
add disabled=yes dst-address=189.9.0.0/18
add disabled=yes dst-address=189.9.64.0/18
add disabled=yes dst-address=189.9.71.0/24
add disabled=yes dst-address=189.9.192.0/18
add disabled=yes dst-address=190.98.146.0/24
add disabled=yes dst-address=200.198.224.0/20
add disabled=yes dst-address=200.198.192.0/19
add disabled=yes dst-address=189.9.128.0/18
add comment=DataPREV disabled=yes dst-address=200.152.32.0/21
add disabled=yes dst-address=200.152.40.0/22
add disabled=yes dst-address=200.152.44.0/22
add comment="Caixa Economica" disabled=yes dst-address=200.201.160.0/22
add disabled=yes dst-address=200.201.164.0/22
add disabled=yes dst-address=200.201.167.0/24
add disabled=yes dst-address=200.201.168.0/21
add comment=Sintegra dst-host=www.sintegra.gov.br
add dst-host=sintegra.sefaz.rs.gov.br
add dst-host=sistemas3.sef.sc.gov.br
add dst-host=www.sintegra.fazenda.pr.gov.br
add dst-host=pfeserv1.fazenda.sp.gov.br
add dst-host=www1.sefaz.ms.gov.br
add dst-host=www.fazenda.rj.gov.br
add dst-host=www.sintegra.es.gov.br
add dst-host=consultasintegra.fazenda.mg.gov.br
add dst-host=www.fazenda.df.gov.br
add dst-host=appasp.sefaz.go.gov.br
add dst-host=www.sefaz.mt.gov.br
add dst-host=www.sefin.ro.gov.br
add dst-host=sefaznet.ac.gov.br
add dst-host=www.suframa.gov.br
add dst-host=www.sefaz.am.gov.br
add dst-host=www.sefaz.rr.gov.br
add dst-host=app.sefa.pa.gov.br
add dst-host=www.sintegra.ap.gov.br
add dst-host=www.sefaz.ma.gov.br
add dst-host=sintegra.sefaz.to.gov.br
add dst-host=web.sintegra.sefaz.pi.gov.br
add dst-host=www.sefaz.ba.gov.br
add dst-host=www.sefaz.se.gov.br
add dst-host=www.sefaz.al.gov.br
add dst-host=www.sintegra.sefaz.pe.gov.br
add dst-host=sintegra.receita.pb.gov.br
add dst-host=www.set.rn.gov.br
add comment=Captcha dst-host=api.recaptcha.net
add dst-host=www.google.com/js
add dst-host=www.google.com/recaptcha/api
add action=deny dst-host=accounts.google.com
add comment=Bancos dst-host=bradesconetempresa.com.br
add dst-host=bradesco.com.br
add dst-host=caixa.gov.br
add dst-host=cmt.caixa.gov.br
add dst-host=conectividade.caixa.gov.br
add dst-host=contadez.cenofisco.com.br
add dst-host=cpo.procempa.com.br
add comment="NF Paulista" disabled=yes dst-address=201.55.62.85
add comment="Simpliss SJBV" disabled=yes dst-address=187.45.245.217
add action=deny disabled=yes dst-address=0.0.0.0/0
I am having the same issue with hAP mini router.
Did you find out why the status is passthrough? and how to make it running?
I have same issue on hAP lite
My proxy status is passthrough and proxy doesn’t work
  > ip proxy monitor
                 status: passthrough
                 uptime: 10m41s
     client-connections: 0
     server-connections: 0
               requests: 1
         total-ram-used: 0KiB
  received-from-servers: 0KiB
        sent-to-clients: 0KiB
   hits-sent-to-clients: 0KiB
> ip proxy export
# oct/26/2022 14:17:48 by RouterOS 7.6
# software id = censored
# model = RB941-2nD
# serial number = censored
/ip proxy
set anonymous=yes enabled=yes max-cache-size=none port=3128
First attempt to use proxy is success, but any other failed. Proxy is silently not working
How I can turn proxy into running state?
I’m already tried different firmwares like 6.47.10, 6.49.7 and 7.6
Please help
