Web proxy-test
Ok… I have web proxy package installed on my router but I need webproxy-test
Where do I get it… how installed? (like all other packages?)
webproxy-test package is in routeros-*.npk (for 2.9.45 version)
upgrade router and you will have that package enabled already, after isntallation, or will need to enable.
for any version - then get the package, upload it through ftp and reboot router.
Ok... I did that....
I can't see it in the packages after a System Packages Print:
print
Flags: X - disabled
NAME VERSION SCHEDULED
0 system 2.9.45
1 user-manager 2.9.45
2 synchronous 2.9.45
3 security 2.9.45
4 ntp 2.9.45
5 dhcp 2.9.45
6 hotspot 2.9.45
7 advanced-tools 2.9.45
8 routing 2.9.45
9 web-proxy 2.9.45
10 lcd 2.9.45
11 arlan 2.9.45
12 radiolan 2.9.45
13 isdn 2.9.45
14 gps 2.9.45
15 calea 2.9.45
16 routerboard 2.9.45
17 ppp 2.9.45
18 thinrouter-pcipc 2.9.45
you must to disalbe web-proxy first. And then you can setup webproxy-test~you try it~I hope can help you~~~
Ok… its installed
however when I redirect traffic to the webproxy-test.. it dosen’t work… no web traffic works
Any idea why it might stop?
http://forum.mikrotik.com/t/what-can-prevent-web-proxy-from-working/15043/1
It is not a good idea to post the same issue details in different topics.
