Web Proxy - Two Wan-s trouble with redirect http traffic.
Hello
I want to add proxy serwer on MT.
I have two WAN-s and one Lan and i want redirect proxy traffic to wan when i have only http traffic.
When I add web proxy serwer all traffic go to my primary Wan wher is other traffic.
I have ROS ver 3.3.
When i type in web proxy src address -address Wan where is traffic for http then can't open any web sides.
What is the reason of that situation?
Thank's for help.
This is my config:
Wan1 - for http, web proxy, dns services and other important
Wan2 - for other traffic
LAN - to to another MT
Ip addreses:
/ip address> pr
ADDRESS NETWORK BROADCAST INTERFACE
0 ;;; DSL 4Mb WWW
83.19.100.82/29 83.19.100.80 83.19.100.87 ether2_DSL4Mb
1 ;;; DSL 4Mb
83.15.248.202/29 83.15.248.200 83.15.248.207 ether3_DSL4Mb
2 ;;; LAN
192.168.1.1/24 192.168.1.0 192.168.1.255 LAN
Ip firewall Nat:
chain=srcnat action=masquerade src-address=192.168.1.0/24
chain=dstnat action=redirect to-ports=3128 src-address=192.168.1.0/24 in-interface=LAN
dst-port=80 protocol=tcp
/ip firewall mangle> pr
0 ;;; Oznaczenie ruchu proxy
chain=output action=mark-packet new-packet-mark=proxy-hit passthrough=no
out-interface=LAN dscp=4
1 ;;; ICMP
chain=prerouting action=mark-routing new-routing-mark=DSL1
passthrough=no in-interface=LAN protocol=icmp
2 X ;;; FTP
passthrough=yes in-interface=LAN dst-port=20-21 protocol=tcp
3 X ;;; SMTP
passthrough=yes in-interface=LAN dst-port=25 protocol=tcp
4 ;;; DNS
passthrough=yes in-interface=LAN dst-port=53 protocol=udp
5 ;;; HTTP
passthrough=yes in-interface=LAN dst-port=80 protocol=tcp
6 ;;; Proxy
passthrough=yes in-interface=LAN dst-port=3128 protocol=tcp
7 chain=output action=mark-routing new-routing-mark=DSL1 passthrough=no
out-interface=LAN dst-port=80 protocol=tcp
8 chain=output action=mark-routing new-routing-mark=DSL1 passthrough=no
out-interface=LAN dst-port=3128 protocol=tcp
9 X ;;; HTTP proxy
10 X ;;; POP3 Secure
passthrough=yes in-interface=LAN dst-port=110 protocol=tcp
11 ;;; SSL
passthrough=yes in-interface=LAN dst-port=443 protocol=tcp
Proxy:
/ip proxy> pr
enabled: yes
src-address: 0.0.0.0
port: 3128
parent-proxy: 0.0.0.0
parent-proxy-port: 0
cache-drive: secondary-master
cache-administrator: "webmaster"
max-cache-size: unlimited
cache-on-disk: yes
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 3d
serialize-connections: no
always-from-cache: no
cache-hit-dscp: 4
IP route
/ip route> pr
DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 A S 0.0.0.0/0 reachable 83.19.100.81 1 ether2_DSL4Mb
1 A S 0.0.0.0/0 reachable 83.15.248.201 1 ether3_DSL4Mb
2 ADC 83.15.248.200/29 83.15.248.202 0 ether3_DSL4Mb
3 ADC 83.19.100.80/29 83.19.100.82 0 ether2_DSL4Mb
4 ADC 192.168.1.0/24 192.168.1.1
Table:
/ip route rule> pr
Flags: X - disabled, I - inactive
0 routing-mark=DSL1 action=lookup table=DSL1
1 routing-mark=main action=lookup table=main
Best regards
Tom
dear Tom
show me /ip route print detail
That is my ip route
/ip route> print detail
0 A S dst-address=0.0.0.0/0 gateway=83.19.100.81 interface=ether2_DSL4Mb
gateway-state=reachable distance=1 scope=30 target-scope=10
routing-mark=DSL1
1 A S dst-address=0.0.0.0/0 gateway=83.15.248.201 interface=ether3_DSL4Mb
routing-mark=main
2 ADC dst-address=83.15.248.200/29 pref-src=83.15.248.202
interface=ether3_DSL4Mb distance=0 scope=10
3 ADC dst-address=83.19.100.80/29 pref-src=83.19.100.82
interface=ether2_DSL4Mb distance=0 scope=10
4 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.1 interface=LAN
distance=0 scope=10
That is mangle:
/ip firewall mangle> print detail
0 ;;; HTTP
1 chain=output action=mark-routing new-routing-mark=DSL1 passthrough=yes
2 ;;; Proxy
3 chain=output action=mark-routing new-routing-mark=DSL1 passthrough=no
4 ;;; mark proxy traffic
5 ;;; ICMP
I got working web proxy on second wan but
I have another problem when I enable web proxy i have many times out connection.
Web sides loading and sometimes connections break and web side don’t responding.
What is the reson off that?
Thank’s for help.
Tom
i got the the same prob … how did do that??
You need to add two routing marks in mangle. Make sure these rules are numbers 0 and 1 in your mangle list.
/ip firewall mangle
add action=mark-routing chain=prerouting comment=“” disabled=no dst-port=80 new-routing-mark=HTTP passthrough=yes protocol=tcp place-before=0
add action=mark-routing chain=output comment=“” disabled=no dst-port=80 new-routing-mark=HTTP passthrough=yes protocol=tcp place-before=1
Try this.
ITway, this is PLAGIARISM. You should have quoted the source or better still, paste a link to the original source.
Sorry
http://forum.mikrotik.com/t/help-please-mikrotik-v3-x86-webproxy-issue-using-2wans/19211/1
That is better:) ?
But I have still the some problem, when web proxy is enablet are to many timeouts connection.
In ver of MT 3.4 is the some, when i type src address in web proxy src address then proxy don’t working.
I’m tyred of try and try againg.
Something in that config is bad.
Mybe something in MT version.
Can anyone help me with that problem?
Best regards
Tom
I don’t have any idea what to do which that problem.
How solve in web proxy src address to redirect trafic on second wan?
Any idea?
Thank’s
Best regards
