Web Proxy used alongside Masquerade
Between my LAN and WAN I have a simple Transparent Web Proxy (port 8080) which works well.
I have two entries for NAT:
src-nat: Masquerade All
dst-nat: Redirect Port 80 to 8080
I believed that my LAN side IP’s would be hidden, but this is not the case.
If for example I use http://www.lagado.com/proxy-test the IP of the particular LAN side PC used is displayed.
I didn’t necessarily expect Web Proxy to hide my LAN side IP’s, but I did expect to be able to use Masquerade to achieve this.
I have three questions:
  1. What am I doing wrong i.e. why does Masquerade not work with my Web Proxy?
  2. Does the ‘Action:redirect’ rewrite the port no. in the packet i.e. change 80 to 8080?
  3. Under ‘IP:Web Proxy’ what is the field ‘Src Address’? it doesn’t seem to matter what value is entered.
Thanks for any help.
Colin
http://forum.mikrotik.com/t/please-include-the-possibility-of-anonymous-proxy/76064/7
I realise I am late but thank you for your response, it is much appreciated.
Colin
