web proxy with 2 isp in 1 mikrotik
we have 2 isp connected in one mikrotik. and we are able to separate the connection (192.168.0.0/24=ISP1 and 192.168.1.0/24=ISP2).
but when tried to we enable web proxy, all http traffics going to ISP1…
is there any way to keep separation of the connection when web proxy is enable?
i suspect that all proxy traffic is going through the ISP1 that is set as default gateway and/or is first listed as default gw (destination = 0.0.0.0/0)
IMO if you want to divide traffic that is aggregating from your router you have to load-ballance your traffic on outgoing chain for dst-port=80
that way you may achieve that proxy is working through 2 gateways.
as far as i know that is not that simple if your proxy is on the same machine where load-ballancer reside
