web proxy
we have updated our MT cache box 2.9.34 to MT 2.9.38 as per forum suggestion but we are still facing problem i cache.CPU ussage of 100% within short period of proxy running.
is still ttheres bugs in web proxy
Did you try web-proxy-test package as suggested in that forum thread?
ya i uloaded in router but its not being update showing system disable
well, if it is installed and showed in package list, you have to enable it first. If I have understood you correctly then you haven’t enabled it.
/system package enable webproxy-test
package is installed and showing in package list and in shedul-shows sheduled for enable.But when i restart it nothing happened i remains same
I haven’t seen anything like this before. Maybe try to use netinstall to completely reinstall routerOS. If that does not help, make supout.rif and send it to support.
check if version numbers DO match.
yes verson number is same but name is ifferent
its
web proxy : 2.9.38
web proxy test :2.9.38
thanks it was same version problem
now i will check performance
thanks a ton
caching is powerfull that older verson but problem of having CPU ussage is still 90-100%.
How can i improve it ant idea.
I am not pretty sure but my proxy got attacked from outside (Internet Zone). The CPU was 100%.
Try to change the port.
allow access to your proxy only from inside of network. all connections to that port and from outside - should be dropped with firewall. in fact, access to your router from outside should be limited to ssh and only from allowed subnets.
