hi everyone…how are you???
i just want to know how to configure ubuntu squid server in mikrotik…
i have running squid proxy server…and when i put my squid’s ip to my browser proxy setting then it works fine…
My quistion is how to configure proxy server to mikrotik as parent proxy..
make sure you change the interface to the network that you want to use the proxy. Also this wont work if squid is on the same subnet as the clients you wish to use it.
thanks.but one more question..i m using ether1 as WAN..and ether2 as LAN.so where should i connect my squid…directly ether3 or
Ether2=switch=squid??
Plz help.
well thats a squid error message. so to me that says that the NAT rule worked. can that box browser the internet? I cant help with the squid problem so you may want to jump into a squid forum.
that is what http://google.com is for. Without seeing your config file i dont really know but I think that you dont have squid set to trasparent mode.
you probably have a line that looks like:
hi bro.,
I m sure that i already installed squid server by using tha command,
Sudo apt-get install squid.
And i changed tha line http_port 3128
Http_access allow localhost…what u think??
Plz dont mind.im totally new in linux..
I hope u can really help me.thanks a lot
