Web Proxy
I have configured a Web proxy as below but nothing seems to get inserted into the proxy. I have hundreds of requests to the proxy, but no content is being cached or sent to clients… Am I missing something here? How do I get it to acutally save content?
[admin@Flame] > ip proxy print
                 enabled: yes
             src-address: 0.0.0.0
                    port: 8080
            parent-proxy: 0.0.0.0
       parent-proxy-port: 0
     cache-administrator: webmaster
          max-cache-size: none
           cache-on-disk: yes
  max-client-connections: 600
  max-server-connections: 600
          max-fresh-time: 3d
   serialize-connections: no
       always-from-cache: no
          cache-hit-dscp: 4
             cache-drive: usb1
[admin@Flame] >
[admin@Flame] /ip firewall> nat print
 0   chain=srcnat action=masquerade out-interface=BigPond
 1   chain=dstnat action=redirect to-ports=8080 protocol=tcp
     in-interface=wds-bridge dst-port=80
BUMP
Hi. Did you checked store?
[otgonkhuu@MobiNetClassic] /store> pri det
Flags: X - disabled, A - active
 0 X name="user-manager1" type=user-manager disk=primary-master status=backup
 1 X name="dude1" type=dude disk=primary-master status=backup
 2   name="Proxy" type=web-proxy disk=sata1 status=backup
I think web-proxy status must be active.
Max. Cache Size=none forces proxy not to cache any files, other values for Max. Cache Size enables proxy caching to disk or RAM depend on th eoption “cach on disk”. Try to set it to unlimited or at least some specific size, and then see the results.
Yes, the status of the store is active.
Thanks - this has sort-of improved my problem.
Files are now being saved to the cache, however, they are not being delivered to clients. The Lookups page Web Proxy Settings say I have hundreds of ‘Not Found’.
Mikrotik webproxy is a very basic version of proxy service IMHO.
You can’t expect much from it, its suitable for small-mid size network for basic caching facility of common objects. For advance caching capabilities, Use 3rd party external proxy server , I will prefer SQUID.
Caching Internet access will require a lot of read and write access to the disk, chose fast disk for maximum performance for concurrent user request support.
Cache performance also heavily depends on RAM size, the More RAM you have in your server, the Better performance you will get.
You can see what content is cached in webproxy cache By going to
IP > Web Proxy > Cache Contents
You can do some tweaks to improve its performance. For example exempt cached contents from user queue.
Read the following for more info.
_http://aacable.wordpress.com/2011/12/29/howto-to-enable-mikrotik-routeros-web-proxy-in-transparent-mode/_
Thanks for the link + tips aacable.
hi i need some help with proxy
i want to setup squid but want it to do the same as mikrotik webproxy
in mikrotk theres src proxy ip + port & parent ip + port
where i want to use my isp’s proxy as it speeds my network up alot as the src proxy
and use my squid server as parent proxy of wich my client uses
ISP Proxy server
src ip = 41.120.216.51
port= 3128
Mikrotik proxy ip (SQUID)
parent ip = 192.168.1.1
port = 8080’
firewall nat = redirect-8080 dst nat tcp 80
1- you can set the parent proxy in the ROS, that should point to your SQUID machine’s IP address.
2- you can forward your network traffic to Squid machine and use the squid as transparent proxy.
