Web Server Behind the RB
OK I have searched and searched and have not found it!! Sorry if its here and I have overlooked it.
My Question
I have a web server behind the router. Using a private IP I have a dst-nat and a src-nat pointing to and from the web server with its public ip xxx.xxx.xxx.242
This has worked for a few years now and no problems!!
EXCEPT every request to the web server is from the router’s IP NOT the requesting client!! So if I was to look at the logs all I ever see it the routers private IP
Is there a way to pass the client to the Web server keeping the clients IP? This is also true for the FTP server
I know the easy way it to move the servers to the public side of the T1’s however I like them behind the router!! Mostly for charting all traffic in and out of the 4 bonded T1’s is through Enet1 and I can see total bandwidth that way and I would lose that it the server was public
You’re NATing inbound traffic in the srcnat chain, most likely there’s a masquerade rule that is too broad. You should add an out-interface=WAN qualifier to that rule.
If you’re unsure, post your NAT rules here to get a specific correction.
